I just started popping Code P0057. I've cleared it several time and it keeps coming back at some point but not immediately. Code Reader says it's Bank 2 Sensor 2 Low. I looked it up and found several causes...... But I can't figure out which Bank is which. Did see a search to no avail.
I'm going to guess!! Bank 1 is the right or Driver Side and Bank 2 is left or Passenger side so bank 2 sensor 2 is probably the rear sensor or down stream on the left side????? Sensor 1 would be up stream????
Is this correct?
Also are the sensors reachable from the bottom????
Thanks.
LBM:serious:
Is this correct?
Thanks.
LBM:serious:
