Hi All,
I installed a backup camera on my 2015 Frontier but am having an issue and wonder if anyone could help me out.
I have an eSky Backup Camera running to a Boyo rearview mirror w/ screen.
The camera is wired off of the passenger side reverse light, with red to red and black to black, with butt connectors. When I put the truck in reverse, everything works like it should. Problem is that when I start reversing, the image flickers every second or two.
Anyone know how to fix this? Maybe black from the camera should have gone to the truck frame for ground instead of to the other reverse light wire? Or maybe the tail light isn't 12v so there isn't enough power? If the latter is the case, maybe I should have pulled the power from the trailer reverse light harness?
Also, FYI for all, there is no fuse that powers on/off with reverse so our only option is to splice wires for the reverse lights (or maybe the trailer reverse light harness). There are two fuses under the hood that seem like they would but both get constant power.
Thanks in advance.
Thanks in advance.
