Axle Vent
11K views 20 replies 15 participants last post by  colin123
#1 ·
Hey Guys -
I just drained my axle to install a Titan Diff Cover. When I removed the fill plug there was a definite pressure release, letting air out; sort of a whoosh (which was definitely heard above the insanely pumping Death Magnetic). I ASSuME this is not normal?! I was going to do the vent mod at some point anyway, but does this mean the stock vent is not working? I've only got 1500 miles on this baby.
#2 ·
it means your stock vent is pluged (or even its craped out) or just nissain installed a crappy part...
#3 ·
Yeah, it seemed to me that a virgin axle vent shouldn't behave that way. Maybe that's why a few M226 axles have been blowing up?
Reactions: Mike L
#4 ·
possably....
#7 ·
some of the m226 came from the factory with out a vent , they just plugged it , check on the passenger side of the axle between the diff and the wheel on the top there should be a little cap id take the cap off and do the vent mod if there is no cap and just a square looking piece sticking up your plugged and need to buy the vent
#16 ·
x2 on that
#9 ·
There is a little silver vent cap on there and it's clean, on the outside at least. Maybe there's a preset that it will build up pressure before release? Doesn't seem right though. I guess the vent mod will be next on my list.
#10 ·
No. It will get clogged and build up positive pressure.
Or it will vent when hot and build a negative pressure after cooling. (It's a 1-way valve).
#15 ·
Just make sure you actually read the entier thread and not just the first post becasue it is wrong.
You can not just use a standard barb fitting like it states, well, you can but it would be wrong.
Order this: #9040451026 from your local Toyota dealer and it will work perfectly. It only costs ~4 bucks and you don't have to worry about grinding down threads or anything like that.
#18 ·
I went to the links mentioned in posts 13,14, & 15. Here's a bit of an update for you. After reading all of those posts, there was mention of the toyota part, BUT I also found a link to a toyota board that mentioned a NISSAN part for their axles.
I looked on courtesy nissan and sure enough, it's a valid number.
I cannot say for 100% certainty that this is the correct part. Hopefully someone will come along that knows for sure.
Anyway, nissan part # = 38323-C6010.
#19 ·
Does this mod apply to the 200 axle also?
#21 ·
yes and i'm almost 100% sure the vent is on the same side too. same vent and same problems
