Have read the threads on the axle vent issue. I think this applies to my 2010 le as well though I don't know what specific axle I have. I base this on the ton of rtv that is applied on every seal on the differential.
I have two questions (I am assuming the fix applies to me):
1. Does the Toyota part number I've seen used work on my axle or is there a different one I should be using? I assume this is the threaded nipple that has a hose barb on one end and threads into the axle where the esisting vent goes.
2. Is there a master table or part guide to find out what specific equipment is installed on my truck? I have such a thing for my jeep which makes finding replacement and swapable parts easy. For the jeep, there are design cues, cast markers, or stamped markers on the main components.
Thanks
Thanks
