What kind of ATF is used? FYI, Dexron III/Mercon is fine for topping off the ATF level, but should not be used for servicing, as it has been found to cause valve sticking in the control valve body. NissanMatic Type "D" ATF or an ATF recommended for Dexron II applications should be used for servicing the trans fluid. Most aftermarket synthetics will work fine, including Valvoline Maxlife ATF and Castrol Transmax Multi-import ATF.
From the service manual symptom chart for slipping, 1-2 shift:
Numbers are in order of inspection. Numbers in off vehicle column mean that the transmission must be removed from vehicle to perform inspection.
* means that valve is suspected of malfunction.
On vehicle service:
1. Fluid level and quality
2. Control linkage
3. Line pressure
4. Throttle wire
5. Accumulator 1-2
6. Control valve:
*pressure regulator valve
*pressure modifier valve
*throttle valve and detent valve
*kickdown modifier valve
2016 sv 4x4 automatic trans cc 4.0 45,000 miles. On several different occasions now when I go to take off from a stop, there is a small slip before the transmission catches...otherwise, I've never had any issues and its a really strong truck. Should I be concerned?
Hey Doyle, this thread is in the first generation forum so the information here will only pertain to 98-04 frontiers. Try making a new thread specific to your issue in the drivetrain discussions forum.
I wish I read this before I drained and filled mine with the Dex/Merc. Glad I saw this post. Just ordered 2 gallons of MaxLife ATF and I'm gonna do the drain and fill again. I have noticed a hard shift when cold going from 2-3 gear since. Thanks smj999smj
113.2K members
