1 - 10 of 10 Posts
2017 Pro-4X w/Luxury Package
Simple to do and just need a new filter, trans pan gasket and the genuine Nissan fluid? Fill through the dipstick I assume?
Mine is operating just fine and I want to keep it that way. I do not want to do one of those pressurized flushes.
Thanks for any input.
You don't need the filter or the pan gasket. Jatco automatic transmissions (used in Nissans) use a screen inside rather than a serviceable filter. As they told me when I was taking the automatic trans course at the Nissan Northeast Regional Training center: "If you have enough debris in your transmission fluid to clog or restrict the screen, then you don't need a filter; you need a new transmission or a transmission overhaul."
There will be a 19MM drain plug on the bottom of the pan. Park park on a level surface after a short drive to warm up the trans fluid. Remove the drain plug and drain into a pan. Replace the crush washer (Nissan P/N 11026-01M02) and re-install the drain plug; torque to 25 ft/lbs. Remove the dipstick and install 4 quarts of ATF. Run engine and check level, topping off the level as needed. Typically, it's about 4.5 to 4.7 quarts, +/-.
For fluid, you can use NissanMatic Type "D" ATF, which is essentially Dexron II. You can also use most synthetic ATF's; just make sure they are recommended for Dexron/Dexron II applications. I use Valvoline Maxlife Full-synthetic ATF, which I can get for $18/gallon jug at Walmart. Castrol Transmax Multi-import ATF is another good choice. *Avoid using Dexron III/Mercon ATF as Nissan put out a service bulletin many years ago stating that it could cause valves to stick inside the valve body. It's okay for topping off the fluid, but not recommended for a full service.
How many drain & fill cycles are needed, just the ONE?
I ask b/c on my daughter's CRV I used an entire case /12 qts ...
3qt drain & drive 4 times to get 82% (?) new fluid in the system.
BTW, my 00' vg33 has 260k and has never been serviced that I'm aware of.
I bought it from my brother in law who bought it new.
TwinSig, IMHO at 260k I would not touch that transmission. Let sleeping dogs lay.
...For fluid, you can use NissanMatic Type "D" ATF, which is essentially Dexron II. You can also use most synthetic ATF's; just make sure they are recommended for Dexron/Dexron II applications. I use Valvoline Maxlife Full-synthetic ATF, which I can get for $18/gallon jug at Walmart. Castrol Transmax Multi-import ATF is another good choice. *Avoid using Dexron II/Mercon ATF as Nissan put out a service bulletin many years ago stating that it could cause valves to stick inside the valve body. It's okay for topping off the fluid, but not recommended for a full service.
I've been thinking about doing the same thing for mine. However, I think I'm just going to do a "drain & fill" come Spring. I'm looking at using Redline D4 ATF:
  • Our most versatile ATF, use where Dexron III®, Dexron II®, Mercon® and Mercon V® fluids are recommended, for use in automatic, manual transmissions and power steering
  • Popular applications: Toyota Type T-III and T-IV, Honda ATF-Z1, Nissan Matic D, J & K, Diamond SP-II, SP-III, Mazda ATF M-V, most BMW and Audi/VW automatic transmissions
  • Also used with manual transmissions and transaxles like T-5, T-45, T-56 and late-model BMW, provides a GL-4 level of gear protection
  • Excellent cold weather operation
So, it somewhat contradicts what was recommended. What's your suggestion? Go or no go?
Yeah, I've heard that in the old days. I may consider a 4 qt (or whatever) drain-fill cycle then drive a couple thousand miles and do it again. NO filter change though, seem useless if its just a screen as mentioned above.
That old CRV I spoke of had a billion miles on it (still going today) and shifted funny but improved after the drain-fill (NO power flush like the jiffy-lubes try to sell)...which can dislodge baked-on impurities releasing them into the entire system and screw it up.
· Administrator
At 260k miles, I'd even be tempted to sneak up on it more than that and only drain and replace 1-2 quarts per oil change.
On the older transmissions, I did a drain and fill every 30,000 miles. On my vehicles with the 5-speed automatic trans, I do a drain and fill every 50,000 miles.
Redline is very good ATF, although expensive. I'm not sure how it contradicts anything?
1 - 10 of 10 Posts
