1 - 20 of 41 Posts
My 07 SE headlights come on automatically when the truck is started.
Is this factory? There is no sensor and no way to turn them off.
If this is factory, is it possible to instead use the markers as DRL instead? I've searched, mainly CF, and haven't come up with much.
I was playing with the idea of using the fogs and markers as such but will settle for markers.
I feel no need to have my headlights on constantly though I can appreciate DRL with an off switch.
Thanks in advance.
My 07 LE has Auto on I usually leave it on and turns on at night but it also has a on off switch. Along with the fogs I have aftermarket housings and DLR wired to turn on with the headlights but its kinda useless. DLR are mainly used to make other drivers more aware of where you are.
You should be able to wire DLR to a relay if you want to separately control them, I dont know the laws.
It's been like this since i bought it in October.
One of my headlights burnt out so I decided to put in a more expensive set of bulbs, but drive mostly during the day.
I'm just trying to extend the life of the bulb.
It should be some type of sensor to detect if its light or dark. Hmm some one might have more experience than me. I hope someone else can help you out I would love to know.
One if there its a sensor.
Two where the sensor.
Three is it easy to change.
I had a 2012 SL ....same as an older SE? anyway my SL had auto on headlights , the sensor is a small eyeball 3/4" on the center of the dash board near the front windshield.
One other thought was ...(and I could be wrong) some of the late model vehicles manufactured to be shipped to Canada had headlights that come on automatically all the time for safety?
I drive with my headlights on any time I'm in either of my vehicles. I have expensive bulbs in both vehicles and not the least bit worried about reducing the life of the bulbs. Been driving my car for over 5 years and 50,000 plus miles with no negative effects on the light output and 2 years with my HID projectors in the Frontier. I do most of my traveling during the day as well.
How easy is it to change your retrofit HID projector (bulbs)?
Discussion Starter · #13 ·
We have had very, very different experiences. I haven't had the pleasure of HID.
There is no sensor. Maybe it was Canada bound at some point. idk
Open the door and look at the VIN tag on the door jam, Does it have a big Canadian maple leaf on it?
It could also be an aftermarket add on.
Do you get just the headlights or headlights and tail lights?
Does it turn off with the key or timed delay?
If you have the factory auto headlights you'll have a sensor on the dash.
No surprise, but my '15 SV has that (non-operational) sensor near the windshield. VTP item(??), but not hooked up...or do they all have this?
Is the sensor for the auto-dim mirror in the mirror itself? Makes sense if it is.
One of the very first failures in my 2008 was the bubble sensor near the windsheild. If my headlights were in auto position my lights stayed on all the time. Sensor was replaced under warranty at about 500 miles no trouble since, now at 108000.
My '17 SV w/ VTP has it too. I wonder if that means it would be significantly easier to add auto headlights? That's a feature I wouldn't mind having.
I have that sensor on my 2015 PRO4x Xterra but I have to turn the lights on (which I do EVERY time I start the car for safety reasons).
Can someone tell me where the switch to turn the 'Auto On' feature on is located? A picture would be appreciated as I have looked for it but cannot find it.
1 - 20 of 41 Posts
