1 - 1 of 1 Posts
Supporting Vendor
Tire & Wheel Specialists
The Chicane RX tire combination results from STI’s years of hands-on experience and proven testing that has produced a broad line of high-performance tires and wheels. Featuring a unique split-knob non-directional tread design, the Chicane RX line is DOT marked and ready to hit the road for powerful performance and high-mileage value. The design’s 8-ply carcass offers the perfect mix of durability, light weight, and smooth ride flexibility.
The Chicane RX is proving itself as a race tire early in the 2016 season. In "Best In The Desert" racing action, the Chicane is helping racers finish in the top 10 by providing top-notch traction and reliable performance.
STI's Chicane RX tires serve owners well with high-performance features including a deep rim guard and a reinforced bead/lower sidewall that allows lower PSI operation. The result is maximum tire performance and durability over a variety of terrain, without the need to run overly high PSI to avoid flats.
Click here for: STI Chicane RX Availability and Pricing
  1. Split-knob, non-directional tread design
  2. Durable and light 8-ply carcass gives a smooth ride
  3. Reinforced bead and lower sidewall, plus deep rim guard
  4. Max performance and strength with no need to run overly psi
-SPECS-
-MEDIA-
Source: stitireandwheel.com
1 - 1 of 1 Posts
