Just a note to you guys, who had me doing the retrofit headlight and purchased the wiring kit from theretrofitsource.com. The wiring, fuse box, and plug seem very easy to get corroded. I found out on mine last night that the 20A fuse box was losing contact caused by corrosion and the plug was also loose. It is best to have all the contacts greased before installation.
Thought that I would pass this out before you run into problems like mine.
