Hello,
My 2003 4x4 SC won't shift into 4th gear until it's warm. This is an intermittent issue so it doesn't always happen but when it does, it sometimes takes 10 - 20 min of driving before it will upshift into 4th gear. It shifts through all the other gears normally so I believe this has something to do with the Automatic Transmission temperature sensor. I saw one other post on this forum but there was no definitive answer so I was wondering if anyone has had run into this issue before and what the fix was. If the AT temp sensor, how hard is it to change this?
Thanks,
Bryan
Thanks,
Bryan
