cycles on/off. kicks on initially to lock than doesn't kick in very often after that. //end thread jack//does the compressor run non stop to keep the locker engaged or does it just fill the arb to a certain pressure then cycle on and off to maintain pressure
Merry Christmas to him hahaNow that you've seen the inside, you should be able to fab one up no problem Penski!
edit: actually nevermind, i see on the other site you already got one!
Where's my arb christmas present?Merry Christmas to him haha
Did you have an off road shop install it for you? I'm wondering cause reading through some of the install procedures kinda made me doubt doing a self install. Things like drilling a hole for the air line and setting the gears back up...etc.very impressed with the details ARB goes thru to make it an easy install
the guy that installed it said this is by far ARB's best design (little changes were made but all good), and the compressor install wasnt bad at all
took me more time to figure out where to mount it and make a bracket for it than it did to wire it
