When I finished installing my ARB front bumper I had 2 oblong openings where the included marker / fog lights were to go. Pretty cheesy. Since I had already cut off the plastic lower front valence pannel containing my stock fogs to install the new bumper, I re-used them.
By carefully jig-sawing around the original mounts and using a flat piece of the old pannel as filler, I filled the entire hole with a factory look. Some s.steel fastners and some trim finnished the job.
Next job is a couple of D-ring tow rings so I can get rid of the low-hanging hook under the frame. Any suggestions?
