done it....2 ways
http://www.clubfrontier.org/forums/f23/jerry-rig-ram-air-17457/index2.html , one like Pro 2x mention, where I directed air from the fog opening to Airaid air box (not really ram air) but turned my CAI set up into an actual COLD air intake, and not just some warm air under the hood intake like most everyone has. Not long after I installed it, we had 4 inches of rain fall in just a few hours...I successfully drove through about 24 inches of water while rescuing 5 different cars and trucks that night without any water going into my air box. This was due to the combination of how the plumbing ran up to the air box effectivly using gravity, and the fact that it was not connected directly into the cone of the filter. To keep the truck asthetically pleasing to the eye and not just have one side uneven, I added a second similiar set up to the passenger side that ran plumbing to the throttle body, since I removed the HOT radiator line running into it which while at opperating temps would negate the cold air that just entered and heat it just before it entered the plenum.
*[ the draw back to this set up was gas millage]*
After fuel prices went through the roof, I had to remove it. In the cold winter months I was actually getting my intake so cold that I was gaining ponnies, but at a price. See the not so convenient thing about the ECU is that it can sense these changes and change the A/F/Ratio adding more fuel for essentially more air.
2) The second option Im working on was a more traditional ram on the hood. I purchased a fiberglass set up from AC(automotive customizers) which I then mounted with the 3m double sided tape and the screws provided. Then I took the leap and cut up my hood and removed the mock plastic pieces that prevent air from entering the fake scoop, and it worked and looked good, (IMO at least). Ive been driving with it just pulling cool air into my engine compartment and removing warm stagnant air away from the headers and plenum. Im still working on a design that will mount on the underside of the hood and will direct some of that air into my box. As well as using fiberglass bondo to mold the scoop into the hood permenantly. But like I mentioned ealier, I would like to get a chip or the guys from Austin to grab my ECU by the balls and take control of the A/F/Ratio so I can have some useful gains and reasoning to this maddness.
