1 - 8 of 8 Posts
does anybody have a good write-up on a how-to? My fan clutch is toast, so its time to convert.
It'd be for my first gen, second gen still good.
Did you ever do this? When I had my truck in for service the dealer wants $375 to replace my fan because the clutch failed. I can wire up a dual fan setup for cheaper than that.
Since you are a 1st gen, you should look into the maxima efan set-up that a few members are running. It is reported to have great results and it pretty cost effective.
Are there any threads on this?? I have a couple Maxima's laying around. Would be interesting to do.
There is a Search function on the upper right corner of the page. If you use the advanced version and search for titles with maxima or fan or etc... you should be able to find a few threads. Also, if you search specifically in the 1st gen section, it may narrow down the results.
1 - 8 of 8 Posts
