1 - 13 of 13 Posts
Trying to decide between running 17's or 18's on the Nismo. 285/60-18 is roughly the same OD as the stock 265/75-16's, but will the added width cause any rubbing without a lift? I also don't want to remove the mudflaps either. If anyone's done it, let me know. I've noticed getting a true A/T tire in this size is tricky as well - far more options out there for 17's....
Discussion Starter #2
No one is running 18's on this forum? Discount tire says they'll fit, but I'm not sure I trust them given their track record with this stuff....
Discussion Starter #4
im running 18s
I had 285/65/18 and now 33/12.50/18s
theres a silver crew cab with cooper ltz 285/60/18s on here but I forget his name
Yeah thats what I am looking at for tires - the zeons. I assume yours was probably lifted with the 65"s?
285/60/18 right here mofos
With some trimming
Depending on the rim... Stock wheels should be AOK
Well I am going to be running the nismo 18" wheels. IS it just the plastic fender lining that would need to be cut?
Most likely. You will be fine
Discussion Starter #13
You can check em out on tire rack, but here's a pic. Great deal right now, but I couldn't swing the tires yet - stil saving for those. I test mounted them on the truck and I think they'll look good.
1 - 13 of 13 Posts
