1 - 20 of 38 Posts
I put a few bags of sand in the back (60lbs each). Not sure of all the pros/cons. I think the 120lbs isn't going to make too much of a difference but it gives me a little something to use if getting stuck and needing traction, a little weight in the bed and takes up a small amount of rake. When going off roading, I'll also take my traction boards and those 2 things are better than nothing. Anyone else do that? If so, how much weight do you carry around on the daily?
I have a crew cab pro4x and the weight feels slightly stabilizing but unnecessary. I do like the idea of having sand if needed and easily getting rid of it when I don't. I put the sand over the axle though...so it doesn't fishtail.
I carry 4 fifty pound bags up against the bulkhead which is right over the axle on the crew cab. Definitely helps keeping the rear composed. I'm not buying that bit about them turning into projectiles and coming through the back window (past a hard tonneau cover) in a crash; if said crash is that bad, then the sand bags will be the least of my concerns.
I have a the Diamond Back cover so the 80-90lbs on top already helps with my traction and ride. I was looking into putting a couple 40lb bags of kitty litter in the bed (could use the litter as oil dry or traction assist outside the vehicle), but after driving it through the snow/ice a few times this winter, I was comfortable enough to know where the "breaking point" was for the truck. I don't think another 80lbs of weight would have made THAT much of difference IMO. Doesn't matter how much weight you have back there, traction WILL break at some point. ;)
Reactions: mikewchandler
yep!!, but if you bump those sand bags up to at least 300lb it will be much more effective as far as a traction aid.
If you have it covered or secured, you're all set.
But if not, it's basic physics, and it's not changing for you.
Hmmm...basic physics doesn't quite explain how a 50lb bag up against the bulkhead goes up then forward through the back window. It's been a while since high school but I do remember that inertia tends to be linear, or close to it. Even without a bed cover I'll roll the dice and keep the sand bags .
2015 Pro4X
Cinder blocks anyone? I made a 2x6 frame (screwed together) including some under to hold 6 cement blocks for weight. If need be I can stand some up and add more. I used to use 24"x30" cement patio stones. Got to be too heavy to lift in/out and move around so I went to the blocks. Could easily be replaced with sandbags if you prefer.
Wood Automotive exterior Rectangle Gas Metal
Pete
I have the 2wd 4cyl KC, so with 400 pounds on the axle I have a 45%F 55%R weight bias to the rear and has amazed me several times on how well it will crawl through places I used to have to have 4wd for. I don't experience any snow here, but I agree the sand bags are handy to have to spread on ice or snow I would imagine. Also the ABLS is really great for a 2wd with the extra 400lbs of sand in back.
1 - 20 of 38 Posts
