what titan db kits would fit frontiers?
it makes sense and ive heard before that some titan lift kits will fit frontiers w/o mods but does anyone know exactly which kits these are?
just curious
They will all work on the Frontier. We have the same frame. Only difference is the length of the uca/lca and the hubs on the spindle. If you are looking for a kit with spindles, you will have to use titan brakes on the front with wheels and then might as well do the same on the rear with a Titan axle.
so if one were to use a titan db then you would have to use the 6x5.5 bolt pattern w/ titan brakes?
