looking at the factory intake tube, the only thing keeping us from simply putting a cone filter on the end of our intake tube is the sensor that is part of the air box. im tempted to cut the air box off where the tube starts, and put a filter on it lol. but surely within a few days the plastic would crack and filter would fall off and i would feel like a newb and have to break out shims and duct tape..... but if someone could machine an aluminium flange like the one on the box and weld it to a 3" aluminum pipe 6" long, the problem would be solved. if somebody will make this magical piece you will be the SH!Z!!
if one had a CNC and could weld aluminum, you could bang them out quick and the materials should be cheap. one could make some good side money at $20-30 a piece with little effort. then we could just pick up an intake filter from $20-60 and making a heat sheild would be cake for anyone who has half a brain, and $10 at home depot lol. it would be much better than the $200-$400 intakes we're getting bent over for now, and the stock plastic pipe should be better than a metal pipe that will heat soak.
if anyone can machine out the flange, that would be awsome, all the older nissans "cars" you could just buy an adapter flange and filter off ebay for $22 shipped, it would be this simple and cheap for us too if someone will make this
it would be:fantastic:
