1 - 10 of 10 Posts
I'm trying to remove the differential lock position switch but I can't get a combination wrench on it (not enough clearance.)
Any ideas?
disconect the wire father up and just leave it? or get a shorter wrench.
I don't think you are understanding the problem. I'll try to explain it better.
The wrench length is not the problem, it is the clearance around the switch. That's why I tried to show a good picture of it
I have tried disconnecting it at the harness but the closed end of the wrench will not fit over the plug.
I am trying to remove the switch to fully understand what exactly the problem is. As far as I can tell, the switch is bad, in witch case it would need to be replaced. If the switch isn't totally bad I don't really want to cut the wires.
There has to be a way to get it off. How did they get it in there? ...maybe a special tool, I hope not. I guess if it really came down to it I could probably try to make my own special tool out of a normal wrench.
I just thought somebody might have a little trick or know of a tool that might work.
its not the same size as a spark plug/O2 sensor is it?
It might be. I don't remember. I think it was 19mm. Why does that matter?
Before you try to pull it out, test it. You may need a lab scope to do it but it's the easiest way. What problem are you having?
http://www.clubfrontier.org/forums/f23/cant-get-solid-diff-lock-light-54894/
Above is the thread where I was trying to figure out the problem. I'm pretty sure I have it figured out already. You know how it is though, I want to get my hands on it to play with it and see exactly what is wrong... bad electrical guts (unlikely I guess) or broken tip (I don't know how it would have broken though.)
Vice Grips. Lock it down on that ***** and crank.
Discussion Starter · #10 ·
I was thinking I would probably have to make my own tool. The O2 sensor socket is a good idea. It isn't the right size though. I just picked up a 19mm deep socket. It has pretty thin walls so it should probably fit after I grind a slot out of it for the wire.
1 - 10 of 10 Posts
