Ok 959frontier or Jordo. I have the same HID Halo headlights and have had nothing but problems with them. I love these headlights and don't want to go back to stock but don't know what to do. I have replaced both ballasts under warranty but my passenger side keeps letting in moisture. I have taken out the turn signal to let it air out and then used a ton of RTV sealant around the whole light seal and the back cap that covers the bulbs. Everything was fine for a couple days now my Halo rings on the passenger side are barely working. The lights in the bottom of the rings are on but the rings only light about half way up around the rings on each side. the Leds still work fine. I've had these lights less than a year. What can I do? What have you guys done to keep yours working great?
Well, actually i bought a second set cuz i got so fed up with it and tossed across the yard. With the second set i rtv around the edges, rtvd ALL the vent holes. Since you got the HIDs like i did, they had to cut out the back housing to run the wires for the HIDs. Thats the main problem for the moisture inside. I just opened the back up (there are four screws), then run a FAT bead of silicone (i used gasket maker) around the top half, then another FAT bead on the headlight housing itself. Make sure you get it all around the HID wires, if not, water will seep through. Seal them up but dont screw it all the way, leave about a quarter turn from tight, wait about 15mins, then tighten the screws all the way. Let dry for a couple days. Theres probably goona be some moisture still trapped, so just take out your blinker and fire up your high beams for 10mins or so. Since i did this ive not had a DROP of fog in there! After a year of battling it out, i FINALLY got rid of it! AHAHAHA!!!! Anyways, good luck! I know how irritating it is.
