1 - 11 of 11 Posts
Need one for occasional use. I think I found my solution. Hoping for feedback from an actual owner. I have the UtiliTrac.
Base plates supposedly bolt to existing holes in bed...
Thanks in advance!
Sent from my SM-N950U using Tapatalk
Thanks in advance!
Looks like maybe no bolts needed for base...
Admittedly I do not have personal experience with this product when I make this comment, but it looks like it uses pressure between the lip of the bed and the floor of the truck to retain itself. It does not look like it's terribly well attached.
If I were in your shoes and wanting to use this, I would see if it's possible to add another fastener that connects to where the D-ring cargo tie-downs lower in the bed are positioned. The result would be two points with fasteners anchoring it to the bed, plus the downward pressure on the floor of the bed.
Does this bolt to the Utilitrack at all?
Would not use it without attaching to the floor with a bolt.
Good point. Not opposed to that suggestion. This would be used rareley, though would have come in handy first days I had her. Built a loft ladder for my nephew in DC a couple days after I picked her up. Had to build in 2 parts as I didn't like options for moving lumber over 6 feet long. 2' x's, pipe, gutters and the occasional 28' ladder are about it.
Concern is stress on both rail and bed floor.
Looks like one bolt acts like a cam in the track, same as the cleats, similar to such tracks on router tables, etc..
I had a sort of light-duty headache rack on my first '95 Hardbody. I was planning on moving it to my second '95 Hardbody but since it was an open frame with no glass protection I'd planned on having some added before installing it, but we bought the new truck before I got around to doing it so it went to Dad along with the truck.
I used that headache rack to protect the back of the cab's roof against things ~10' long several times. If I get my canopy lift/removal system for the garage I'm tempted to get a removable headache rack for the Frontier, and to also get a second upright that would go near the back end of the bed so that if I needed a pseudo-pipe-rack or ladder support or the like I could add one temporarily and it would be wide enough to carry something big like plywood.
I’d add a plate to the foot and attach it to the utilitrac in the bed floor and then it would be secured top and bottom.
They also make it in an all aluminum version.
Reactions: mlwinnig
Leaning towards this one now!
Yes I know. Not exactly the same. Thinking more useful, less risk of issues without drilling.
Thoughts?
Thoughts?
Bummer! Won't fit.
Anyone know of similar design which will?
I like that one as long as you always have help available when you need to remove it. I went on their site and saw a nice two piece aluminum set that I’m now considering as I can easily install and remove by myself and weighs very little. The full rack weighs about 164 pounds.
I use a tri fold bed cover so I’d never leave it on as I need the bed dry and covered all other times.
Discussion Starter · #11 · (Edited)
Ah. Good point. Likely not the case for me. I think I would leave it on most of the time but ability to remove and install alone is a plus. Please post details on one you are considering.
Saw one which works with cover but it is $1k. Guessing cover not cheap either.
New post shows one which should fit...
1 - 11 of 11 Posts
