1 - 4 of 4 Posts
It unscrews, but it may not "simply unscrew". Spray it with some PB Blaster for a few days, then carefully back and forth until it breaks loose...or breaks off.
I went to swap mine the other day. It snapped off very easily. It was all rusted inside and the stud is now stuck down in the base. Rather surprised how quickly it rusted. It's a 2017 that's only been through 2 winter's with salt.
Given that the antenna is exactly the correct height to warn you if your driving under something that is too low, why do you want a shorter one?
1 - 4 of 4 Posts
