1 - 4 of 4 Posts
Would Titan rims (and tires) interchangable with Frontier? Is it the same bolt pattern and/or back spacing. I REALLY REALLY REALLY want to put 5 steel rims and snow tires for an awesome Ohio winter weather. Thanks.
Paul/ '10 Frontier CC LE 4X4
'01 Honda 400 ex
titan wheels will not work on a gen 2 out of the box, they are a different bolt pattern
Like Irongrave said, Titans have the 6x5.5 pattern while the Frontier is the oddball 6x4.5 pattern. It was only used on the 2nd gen Frontiers/Xterras/Pathfinders and some of the older Dakota/Durangos. The deck is stacked against you again since the Dakota rims won't fit due to the diameter and the backspacing/offset so you are forced to get either aftermarket or oem Nissan steelies.
This may be an option for you: http://www.clubfrontier.org/forums/f114/fs-set-4-oem-16-steel-rims-62221/ (shameless plug). If you are interested, just PM me and we can see if we can work a deal.
1 - 4 of 4 Posts
