1 - 14 of 14 Posts
I am going to get another cowl and paint it myself. Does anyone have the part number for the cowl? Dealership wants $84 for it and I have found places online for around $55 but they show 3 different cowls. Anyone know the difference between the 3? I would not of thought there was any. I would repaint mine but looks like someone tried to steal the driver side wiper arm and chewed up the cowl a little bit.
My next question is a painting tips. I plan on doing it myself just curious about sanding, what type of paint, etc.
1. do you have satellite radio, use normal radio? If you have satellite or don't use the normal AM/FM radio the pathfinder cover dose NOT have the mount for an antenna thus cleaning up the cowl looks wise.
2. for the diffrent part number I only know of 2 the Frontier/Xterra one with the mount for the antenna and the pathfinder with out a mount for the antenna.
3. painting,
a, green scuff pad over the hole surface and a good wipe down with a degreaser type product or wipe, Touch-Up Repair Prep Wipe
b. a good plastic adhesion paint, Adhesion Promoter
c. follow that with what ever color you chose
I removed mine, just wiped it down with alcohol, and used a rattle can of automotive paint as close to my truck color from Autozone and painted it. Looks good and has lasted over 1.5 years so far. Good thing is I can do it again if it ends up looking bad. 6 bucks for the paint.
Discussion Starter · #12 ·
Thanks everyone. I may try to sand the gauged spot and paint the old cowl first. Hopefully I can get it smoothed out a little bit and try some paint. I will get a new cowl if that doesn't work.
1 - 14 of 14 Posts
