1 - 20 of 92 Posts
Has anyone angle cut their bedsides??? If so how?! Example...
I know these are glass... But i'm talking about cutting the stock bedsides. I plan on doing at least... this, this year plus a fabed rear bumber. Any input is gladly welcome.
Discussion Starter · #2 ·
Bump, before I go to sleep...
What happened to this forum..?
I'm talking about...
you better undercoat the hell out of it if you do
Here's another example... This is actually exactly what i want to do to it. M1key from Titantalk did it with a sawzall and he said it was a *****... I was wondering if there is a better way of doing it.
And to add to this topic... Does anyone know about "rolling" bedsides..?
Ah... Good idea... More clearance... I like the steep angled look though...
Discussion Starter · #10 · (Edited)
I plan on using a 3" air cut off tool, with plenty of blue tape.
Here we go!! I'll put this on my suggestions list...
Hmm... I'm gonna look into buying one now... Looks like these would cut through like butter... You... think it would???
Also... Do you plan on painting it after you the cutting???? (Rust worries me...)
a grinder will cut pretty straight and easily with a cutting blade. use a straight edge to find the angle you want and have a friend trace ith with a sharpie or something. then cut and enjoy.
i'd def paint it after cutting, or bedline it or something. that will rust up in a heartbeat if you do not protect the metal in some way
+1 for angle grinder with cutting wheel, should work easily
Discussion Starter · #15 ·
Sweet thanks everyone... I'll definitely post after I do it.
I cut my 1st bed before I got my flatbed. I used a grinder with a cut off wheel. Lay down a layer of painters tape where you want the cut. Then lay another piece right along side it and cut where they meet. Just make sure you get your body in a comfortable position so you can make the cut in one motion. If you have to start and stop it will be much more difficult. I also cut away everying about an inch below my final cut so I wouldnt have all the excess material in the way. That really helped since there wasnt any weight to pinch the wheel in the cut. After it was cut I sanded the burs away and taped about 1/4 inch above the bare metal. A quck sand followed by some high quality self etching primer (I used the green rustoleum stuff) and toppped off with black enamel paint. Never had a problem. Oh yea, then I taped everything off and shoot some undercoating on the backside.
are there pics of your flatbed floating around somewhere? i didn't see them. (and would like to)
1 - 20 of 92 Posts
