Ok guys i am new here but have been a lurker here for a looong time! OK so here is goes.. I drive a 2002 Nissan Frontier XE 2WD Desert Runner ..my problem started this morning. I started my truck up and took off to work i got about a half mile down the street and my truck all of a sudden would not rev past 2000 rpm.. so i turned around to bring her back home slowly, I got almost home and it stopped. i was able to drive again and went to work. on my lunch break the exact same thing happened lasted a few minutes then i was able to drive again. so i got home and hooked up my scan tool. Now my check engine light was already on for the fuel temp sensor being bad ( got the parts on order). but another code was there P1490 Vacuum Valve bypass Valve.. is this my issue with the Limp mode? or do i have other problems. I tried to clear the codes. and drive around a bit and its still happening with the same codes coming up
any help with this would be great !
