I did a quick run through the stickies and common problems but didn't see much talk about the alldogs rear diff vent. Has anyone put this on their rig? And what do you think of it? Year mileage..thanks!
Just buy the parts and do it yourself. Cheaper and it works. I have had mine on for 80K+ miles and no issues. If there were to be a drip of condensation getting in it wont destruct anything.Darn I was hoping to get a little more feedback. The reasons I get nervous about a filter behind the tail light is I've seen guys talking about moister condensing in the line and dripping back in the diff that way. And to me running lines through frame holes and body panel holes makes me think it will rub through the rubber line and be open to the atmosphere. I've had that happen to me on other vehicles
The Diff probably generates condensation anyways with always going from hot to cold so little drips from that line won't affect it as you're specifying.Just buy the parts and do it yourself. Cheaper and it works. I have had mine on for 80K+ miles and no issues. If there were to be a drip of condensation getting in it wont destruct anything.
I just bought one for my 2005 because it's 15yrs old & looks rusty like alot of the undercarriage...but I pulled out the factory one & it functions perfectly. I blow through it & hear the valve pop open easily, then suck & is shut off completely plus the cap moves freely, granted my '05 has only 32k miles, which is also why I will never put my rear end under water intentionally.I did a quick run through the stickies and common problems but didn't see much talk about the alldogs rear diff vent. Has anyone put this on their rig? And what do you think of it? Year mileage..thanks!
I just went to go put on the ADO rear diff breather today and then got to thinking about if it was really a good replacement option. Then I read on FB of a guy who had his rear diff fail because of the ADO breather. Then I did some research and found this post. I pulled the ADO breather and tried to blow through it - it feels like a clogged and rusted OEM breather would. Actually not very reassuring. Put my OEM breather back on for now since it only has 1600 miles on it.I just bought one for my 2005 because it's 15yrs old & looks rusty like alot of the undercarriage...but I pulled out the factory one & it functions perfectly. I blow through it & hear the valve pop open easily, then suck & is shut off completely plus the cap moves freely, granted my '05 has only 32k miles, which is also why I will never put my rear end under water intentionally.
The Alldogs unit is Stainless steel👍but blowing through it's stationary membrane is very hard, so I put back in my factory breather for now. It was only $15 shipped & comes with a cool decal which would be worth $5 itself. I don't know how much air pressure release is needed to keep the seals from blowing or what the Alldogs pressure release rating is...but in comparison I feel that the Alldogs' presure release is like a clogged factory unit🤔
So there's that for everyone
View attachment 323134 View attachment 323161
ADO makes very good stuff overall but I take exception with this one. This idea is junk, regardless. You're going to submerge your axle vent and then depend on a selective membrane to keep water out when you could just move it up behind your taillamp, install a $7.95 K&N breather filter on the end and call it a day, which is exactly what I did, except I went one step further and placed it inside a $5.99 sports drink cup from WalMart, with the drinking tube ripped out. Its now 3' off the road surface and is protected from getting wet by the plastic housing. Done and done.I just went to go put on the ADO rear diff breather today and then got to thinking about if it was really a good replacement option. Then I read on FB of a guy who had his rear diff fail because of the ADO breather. Then I did some research and found this post. I pulled the ADO breather and tried to blow through it - it feels like a clogged and rusted OEM breather would. Actually not very reassuring. Put my OEM breather back on for now since it only has 1600 miles on it.
