User BRUTAL has gone to some trouble to provide great information on how to get your truck aligned after a lift.
Unfortunately, the information is scattered throughout the thread (and Brutal isn't exactly a wordsmith). User nismo4x put up a helpful doc on page 9 of the thread.
I've taken that, spruced it up a bit, and generated what I hope is a helpful image to clear up any confusion. You can see the doc here, or just read on.
Note: These are instructions to give your mechanic after you have already installed adjustable camber (lower control arm) bolts per the image below.
TOE: Set toe to factory spec using adjustment on steering tie rods. Set slightly more toed in than the green middle. 1/16" to 1/8" toed in is preferred.
CASTER & CAMBER:The caster and camber settings below have already been made with adjustable camber/LCA bolts and should only be adjusted if I didn't get them lined up exactly as below.
Torque for the nuts on these adjustable bolts is 100 ft.-lbs.
L < (OIL PAN) > R
Note: Check to make sure passenger and drivers side bolts are precisely aligned.
If you appreciate this, consider donating some BTC @ 1DEqxo9nqBwLMdRFv8B8wGa5LDYYvsxWbS
2005+ Nissan Frontier - Alignment Notes
Special instructions for lifted vehicle Without Aftermarket Upper Control Arms
Note to Tech: If caster and camber are already set as described below, you will only be adjusting toe. Accordingly, check the camber/caster settings against those described below and then proceed to adjust the toe.
Adjust for deflection. Once toe is set, check deflection by pushing out on inside of wheel forcing wheel to take up deflection or "play." If the toe setting on the screen shows the toe moving out beyond spec, give more toe in until the push-out results in the setting going to the middle of the spec. This may cause the "static" toe setting to shows too much "toe in" and be out of spec into the red. I am ok with this; the toe will be at spec when the vehicle is in motion.
Adjustable bolts at rear of lower control arms (camber): Fat side of washer, with notch, should face in toward oil pan. This gives most negative camber and may not be completely in spec on paper, but will be about as close as you can get with this setup.
L > (OIL PAN) < RAdjustable bolts at front of lower control arms (caster): Fat side of washer should face out away from engine. This moves the rear of front tires away from back of wheel well and gives more room without rubbing for larger-than-stock (e.g., 285/75/16) tires. This also gives most positive caster and will make the truck track straight and feel more stable at speed. This setting will be off of factory spec and I'm okay with that. If this gets adjusted to bring back to spec, the bigger tires will rub in the wheel well.
