11/29/20 Edit: Z1 Motorsports now has 2 piece rotors and BBK available!
Frontier Akebono Big Brake Upgrade Kit
Original Post:
I don't actually have a Frontier, I have an R51 Pathfinder. It shares the same front brakes, spindles and hubs, so I thought you guys would like this information, and might want to use it to upgrade your own brakes.
The Frontier and V6 Pathfinder share the same front brakes. Nissan put a little bit larger brakes on the V8 Pathfinder here in the states, and the diesels offered in the rest of the world. These brakes have 320mm rotors vs 295mm. They are interchangeable, so you can get a little bigger brakes with a cheap and simple swap over to the V8/diesel caliper and rotors. Nice and easy.
Now, I have a V8 Pathfinder with the larger brakes, and have not been happy with how the 320mm brakes perform. I am used to European car/SUV brakes and want my Pathfinder (or Frontier) to perform similarly, so I decided to upgrade. I started digging around, and found that the V8 Pathfinder uses the same calipers as a base model 370z/G37, and the rotors were the same diameter too. A popular upgrade for the 370z/G37 is to swap on the Akebono 4 piston caliper and 355mm rotor from the Sport or Nismo models. So, I figured I could do the same on the Pathfinder. I then found someone else had the same idea and made a thread . They were able to bolt up the caliper successfully to the Frontier, but unable find a rotor that worked.
I searched, and searched, and searched for a rotor that would have the super low height of our rotors and a 355mm diameter. Anything off the shelf would need spacers, adaptors, and modifications to work. I came to the conclusion that I would have to go 2 piece rotors to make this work. Z1 Motorsports makes Akebono swap kits for many different Nissan models and while they don't make one for the Frontier or Pathfinder, they do use the same 2 piece rotor in all their kits. They just use a different hat, or center, specific to each car. I figured I could design and make my own hat using their rotors. They have been helpful in my project so far, and their rotors look really nice.
And after much measuring here is what I came up with:
I was happy with how they fit on the rotor. Let's see how they fit on the truck:
They fit nice and snug on the hub, so how does the caliper fit and line up:
It fit excellently. The caliper is quite wide so I had to throw on a spacer so the wheel can clear the caliper:
And now to hide everything:
That is where I am at so far. Now that I know the design fits, I can pick up the other caliper and some other odds and ends, and actually get the brakes installed.
Just a few notes for future reference:
My parts list so far:
I will update with more as I get everything installed. If these perform like I am hoping, I may consider making a run of the rotor hat/centers so anyone can put this same kit together on their own.
Original Post:
- It looks like at least 18" wheels are needed to clear the caliper
- The calipers are quite wide, and the stock wheels need a spacer to clear the spokes
- 370z Sport Akebono 4 piston calipers
- 370z Sport banjo bolts
- 370z Sport brake pads
- 370z Sport brake pins/clips/shims
- Z1 Motorsports replacement rotor rings and hardware
- Pathfinder braided brake lines
- Custom rotor hats
- 19mm wheel spacers
