Did you plug back the wires in properly? That might be a reason why you are getting an indicator warning light on your dash. No recognition of airbag system.I put new carpet and removed my seat now airbag light from unplugging it is on . What's the way to get it off .. Door switch push few times or something ?? Thanx for help
Thanks for the heads up @BigDad!Its a reset code. When I cleaned my seat belts, (disconnected) you have to reset, pretty cool actually.
Click on the red Nissan help forums....How do I reset the airbag blinking light on Frontier 2003? - Nissanhelp.com Forums
Pretty sure it's the same thing, if it doesn't work, like someone said earlier in the thread, recheck all connections. Beyond that I don't know, the reset worked for me when I took my seat belt off for some deep cleaning. Good luck.
