stock filter, rigged CAI, or mix
so today i got a K&N filter to replace the stock one. ive had these before and know they are alot better than the stock ones, but after i got home i saw another pic where there was a cone filter where the air box used to be. now i was wondering what would be more efficient.
1. keep it the way it its now and use the K&N stock replacement and leave the air box alone
2. return the one i got today and get a cone one that will fit where the air box was
3. keep the K&N air filter i have but remove the air box so the intake is just the 3 inch hose that run atop the radiator.
4. would it slow down the air to much to remove the box, use a cheap filter at the end just to keep out larger things and keep the K&N for the stock?
have any of you guys modded the intake like this?
supposedly the cone sucks air from the same spot that the box would have but also lets it get additional air that the stock wouldnt have allowed. any imput would be helpful.
also, i was just going to leave the little inlet tube from the fender wall with the sensor, not sure wether the MAF or temp, there so it wont throw codes for not being there at me but just not attached to anything air related.
