1 - 3 of 3 Posts
just wondering if anyone knows how many cans of r-134a im gonna need to put in after i vacuum out the ac... i have an 01 king cab
Got this out of my '04 service manual for whatever that's worth. Sorry about the loss of table spacing.
SERVICE DATA AND SPECIFICATIONS (SDS) PFP:00030
General Specifications EJS0020T
COMPRESSOR
LUBRICANT
*: Always check with the Parts Department for the latest parts information.
REFRIGERANT
Inspection and Adjustment EJS0020U
ENGINE IDLING SPEED (WHEN A/C IS ON)
Refer to EC-36, "Idle Speed/Ignition Timing/Idle Mixture Ratio Adjustment" (KA24DE), EC-604, "Idle
Speed/Ignition Timing/Idle Mixture Ratio Adjustment" (VG33E) or EC-1205, "Idle Speed/Ignition Timing/
Idle Mixture Ratio Adjustment" (VG33ER).
BELT TENSION
Refer to MA-15, "Checking Drive Belts" (KA24DE) or MA-24, "Checking Drive Belts" (VG33E or
VG33ER).
MAGNET CLUTCH
Model DKV-14C
Type Vane rotary
Displacement
cm3 (cu in)/rev.
140 (8.54)
Direction of rotation Clockwise (viewed from drive end)
Drive belt A type
Model
ZEXEL make
DKV-14C
Name
Genuine NISSAN A/C System Lubricant
Type R or equivalent
Part No.* KLH00–PAGR0
Capacity (total in system)
m (US fl oz, Imp fl oz)
200 (6.8, 7.0)
Type HFC 134a (R-134a)
Capacity
kg (lb) 0.60 - 0.70 (1.32 - 1.54)
g (oz) 600 - 700 (21.16 - 24.69)
I don't know how the 134a and lubricant quantities work.
1 - 3 of 3 Posts
