Truck is a 98 4x4 5 speed. Took out the carpet to wash it, which meant taking out the lower plastic trim with the air bag on/off switch. Air bag Light is now flashing and annoying the hell out of me. scanner does nothing, would I have to go to the dealer and have them reset it? Any way yo reset it myself? Thanks in advance for the help
Try this. If it doesn't work, you'll have to take it to a place that has a scan tool that can access the SRS system:
Open the driver’s door.
Note the rubber covered button located low on the B pillar, a button which is pressed by the door when the door is closed. This is the Driver’s Door Switch (DDS).
Turn the ignition from OFF to ON.
Press the DDS at least 5 times within 7 seconds after turning the ignition switch ON.
Turn the ignition OFF.
Close the driver’s door.
Start the engine.
I've heard about the door switch method. I'd try it but I don't have one on the drivers side, and neither do any of the local auto parts stores
