1 - 8 of 8 Posts
Ok may the sticky Gods have mercy on my soul but I need some current info. Tired of reading all these old 2007 and 2008 threads about lockers and getting no useful information.
I'm in need of a rear diff locker for my 2011 2wd frontier...extended cab truck.
Is there an electric one out there that will work with my diff?
If not an electric one is there an air locker by arb that will work with my diff?
Also if anyone has pics or knows of someone who has done this mod can you please post a link?
Thanks!
DD
Auburn Gear is a limited slip and not a locker. ARB is a true locker and is a selectable system. There are automatic lockers like the "Lokka" which are full time lockers. Can't remember the name of the automatic locker Jen has but it seems to work well. These are less expensive than the other types.
I run an "Eaton Trutrac" in my truck.
What differential do you have,M226 or a CK200?
thanks!
Thanks for the info! I have a 6 speed manual so I assume it's the M226 Dana44....???
Do you remember the part number for that eaton? Thanks
Jen had a spartan locker. She now has ARB front and back.
I am guessing that the OP has a CK200.
IMO the best thing would be to get an entire axle from a nismo.
Just curious, how much would an axle from a nismo run me? new vs. used?
Thanks!
Eaton Trutrac P/N 913A582.
You might want to get the differential rebuild kit also.
1 - 8 of 8 Posts
