Hi All - Does anyone know of a spray on bed liner in a can? Or something along those lines? My bed, which is sprayed from the factory, is faded pretty bad from the sun. Any thought are greatly appreciated..
Thanks,
Dave
There is a couple of different ones, but they suck. They have some others that roll on which are better, but still suck compaired to the pro's (ie. Rynoliner).
Not a 100% but I'm pretty sure they sell the spray/roll in stuff at most major parts stores.
if you think the spray on sucks then your doing it wrong. duplacolor makes spray on liner in the rattle cans. i have used it several times with real good results. surface prep is KEY. since you have the spray in already you will need to scrub it and scrub it GOOD with a good cleaner. then just follow the instructions.
