Hey folks,
Been diagnosing the AFR sensors in my 08 Nismo as I got a P2A00 code (Bank 1 Sensor 1 Low) at the shop.
I plugged in my scan tool (Innova 3040) and scrolled through the live view PID's until I found the two pre-cat sensors.
These are wideband sensors.. my understanding is that the voltage readings should be somewhere around 0.3v-0.7v... BUT my scanner was telling me that the two sensors were running at 2.0V and 2.1V. There's no way this is possible. Both lambda values seem fine, sitting at ~98-99%.
Am I mis-interpreting the data? Is my scan tool inaccurate for some reason? are both my sensors kaput?
Hope you guys can help!
