1 - 14 of 14 Posts
Hey guys, Ive preaty much got all the lift i can out of my TC kit... but i still want to go a bit higher... Ive heard that body lifts arnt very good for jumping/prerunning do to a higher risk of the body mounts failing... but if i put on a 2 inch body lift would that be acceptable?......
think of a desert truck like a sports car, you want to keep your center of gravity as low as you can, so lift and going fast/jumping in the desert don't go good together. You do want more ground clearance that come from tires. Unless your getting cought upwhen your wheeling I would say you good.. Also what makes Buddy lifts bad are then brake down make you body sit funn they also bend the body mounts.
Discussion Starter #3
well i want the lift more so i can put larger tires on, as the truck sits right now, i can only run 31's with out doing an engine cage.... just looking for options.
Discussion Starter #5 (Edited)
ill maybe jump it 4 or 5 times an outing.. most of the time im just mobbing it around the desert. and i only go out maybe 3 to 4 times a year... most of the time im just driving to work and back.
Discussion Starter #7
hes around, im just looking at options.... what i really want is some lift spindles.... if only i had a second gen LOL. I know that they really arnt jump friendly. but anything besides a engine cage to give me some more space for compression/taller tires would be great....
Okay, I know 1st gens are a lot different then the 2nd gens but is there a way in which you could mount a drop bracket and then modify the stock spindle to make it longer?
Discussion Starter #10
already got shock hoops. at the moment i dont want to go to an engine cage.
as for the drop bracket idea. its good in theory, but the stock first gens use T-bars, i havent seen adrop bracket kit for them. and if i do a drop bracket, then my whole geomatry of my front suspension would have to be reworked. i much rather pay for a set of custom spindles... then do that... just looking for a cheeper alternative lol
Okay, I am totally confused then. I thought you were running coilovers in the front which elimanted the shock and Tbars? Are you still running the Tbars?
I guess I will be following this thread to learn more about the 1st gens besides the standard Tbar crank and then blocks/shackles/deavers combo.
Discussion Starter #12
im running coil overs now, but with the length of the coil overs. and the way the lift is designed i would need custom uppers, lowers, and a spindle which would cost more then what i paid for my set up currently.... and right now im not willing to spend that kind of cash lol.
what about new body brackets instead of body blocks.....like custom body mount that sit higher on the frame and are bigger and stronger, I have seen people do it. Actually your in Sandiego, I can take you to see a truck that a guy I know did this too if you want... you just need a bandsaw, a grinder and a welder.
....basically same stuff people do when they do body swaps with custom body mounts.
1/4" plate with a little gusseting and it will be stronger than ever
Discussion Starter #14
Didn't think about that possablilty.... that might work too...
1 - 14 of 14 Posts
