sub'd
Does that mean you’ll be carrying theseWe were able to install D40 Asfir skid plates on the 3rd gen / D41 Frontier yesterday! It was a very easy install with minor modification. Basically, we had to drill 3 new holes into the aluminum plates to allow fasters to run through at different locations. We've documented our modifications and sent them to our friends at Asfir, hopefully they will make the changes to their production pieces soon so that these are a direct bolt on.
Not sure yet. They're available directly from the Asfir website.Does that mean you’ll be carrying these
did you find that the rear cross member provided was about 1/4 inch too short to fit between the truck frame rails?We were able to install D40 Asfir skid plates on the 3rd gen / D41 Frontier yesterday! It was a very easy install with minor modification. Basically, we had to drill 3 new holes into the aluminum plates to allow fasters to run through at different locations. We've documented our modifications and sent them to our friends at Asfir, hopefully they will make the changes to their production pieces soon so that these are a direct bolt on.
Fair enough. And you were able to get both end pieces slotted into the cross member successfully? I can't even slot mine in...Yes, on both the 2nd gen and 3rd gen installs we've done. This is normal and the bracket will snug up as you tighten the fastener.
I can't see how flexing the frame rails 1/4" to snug this up would be a good idea! Correct me if I'm talking nonsense...
Running factory wheels, do you think it would be possible to keep the mudflaps running a 255/80/17 pizza cutter? Using your Koni’s setup.Hey Friends! Here's a build thread for our 2022 Nissan Frontier Pro-4x. We'll try and keep it updated as time goes on.
We've started this build with Koni 82 Series shocks and our medium coils and AAL for the rear. Initially, this truck won't see a lot of extra weight in the bed so the AAL should do nicely without making the ride overly firm. Next spring I'm considering adding a bed rack and possibly a rooftop tent. At that point it it'll probably get a medium load leaf pack like our broverlands or our upcoming parabolic leaf packs. We have a youtube video up showing the suspension install if you want to check it out.
At some point in the near future we will titanswap the truck. There are some changes to overcome to make this happen which we are currently working through.
For tires we've chosen to go with pizza cutters. We were able to pick up some Kenda Klever RT tires in 33x10.5r17. The tread on these tires is very aggressive and the sidwall is insanely thick. The 9 speed transmission doesn't appear to be having any trouble with the larger diameter around town. We'll be doing some highway driving this weekend and will see if there's a big hit to mpg. Road noise isn't bad at all and we'll see how they do wheeling later October. Here's a link to check them out.
Automotive Tires, Passenger Car Tires, Light Truck Tires, UHP Tires | Automotive | Kenda Tires | Klever R/T
that size is basically what tire size Chad is running on the truck. you will just have to trim the inside of the mud guards to keep it from rubbing.Running factory wheels, do you think it would be possible to keep the mudflaps running a 255/80/17 pizza cutter? Using your Koni’s setup.
Bottom Shock mounts low....You ever get hung up on them ?View attachment 353717
It's been a while since we've had time to work on this truck, but last week we added some of our parabolic leaf springs! We have an ARB rooftop tent and Heavy Metal Offroad bed bars and needed a little more weight capacity in the rear. This setup rides really well, I'm excited to do some traveling with this setup in the near future!
that's where all frontier rear shocks mount. nissan didn't change the rear axle design for the 3rd gen except for different gear ratioBottom Shock mounts low....You ever get hung up on them ?
