1 - 15 of 15 Posts
Hi Everyone,
1. I talked to PRG today and was told that my 05 frontier LE CC had adjustable cam bolts. I have checked my lower control arms and discovered that I don't, or at least I think that I don't. Does anyone have any pics of adjustable cam bolts vs non adjustable or perhaps what should I be looking for in order to tell the difference?
2. In case I don't have adjustable cam bolts how difficult would it be to change mine out to adjustable???
Thank you in advance,
Nick
can't you take a picture of what you got and we tell you if they are adjustment cams?
Discussion Starter #5
I just took a closer look and realized that adjustable bolts have a washer with an offset hole. The cam bolt washers have the hole directly in the middle therefore I assume that they are not adjustable.
Please confirm or correct me if I'm wrong.
Thank you
if the hole is in middle then you NEED the cam bolts if you are modding.
Hi Everyone,
Nick
I am pretty sure if you have an early 05 build they didn't come with them. Mine didn't but I was able to go to the dealer and tell them the alignment shop said they couldn't adjust my front end until I got the cam bolts. The dealer actually gave them to me and the alignment shop put them on. I think they later 05 came from the factory with them already on. There was a TSB on this back in 2005. I don't have it anymore since mine were added.
Yours should have them,06 & up dont.They are easy to change,
you have that backwards. 05's and some really early 06's didnt have them. newer trucks did. there was a TSB about them and alignment issues. some trucks needed them, some didnt when it came time for an alignment.
edit, guess i should read all the post before i hit reply. LOL.
'07 and no cam bolts. I had to buy them from PRG.
Wrong
1 - 15 of 15 Posts
