1 - 13 of 13 Posts
Hey all,
The acronyms are killing me. As I'm trying to digest as much info as possible about lifts, I'm finding them so often I'm struggling with comprehension at times. Any chance of throwing together an acronyms list and making it a sticky?
Thx,
Jon
List of Acronyms and Shorthand Chat
Vehicle Specific Terminology
2WD: Two Wheel Drive
4x2: Two Wheel Drive
4WD: Four Wheel Drive
4x4: Four Wheel Drive
6MT: 6 spd Manual Trans
7-pin: 7 pin trailer connector as opposed to the basic 4 pin
A
AAL: Add A Leaf
ABS: Anti-lock Brake System
ABLS: Active Brake Limited Slip
AC: Automotive Customizers (company)
AFR: Air/Fuel Ratio
AT: All terrain (tires) or Automatic Transmission
AWD: All Wheel Drive (usually refers to a full-time transfer case)
B
BCM : Body Control Module
BDGT: Bully Dog GT (tuner)
BL: Body Lift
brake judder: Brake pedal pulsation, caused by warped rotors
BS: Backspacing (wheels)
BTF: Blue Torch Fabrication
BU: Back Up
Burger: The Nissan emblem (because of the shape)
C
CAI: Cold Air Intake
cap: capacitor, also can refer to a bed cover
cat: catalytic converter
cat-back: an exhaust system that replaces all factory parts from the catalytic converters back.
CB: Citizen's Band
CB Contact: Coil Bucket Contact (UCA strikes coil bucket)
CC: Crew Cab
CCLB: Crew Cab Long Box (same as LWB)
CEL: Check Engine Light
CF: clubfrontier.org
CO: Coilover shock
CST: California Super Trucks (suspension manufacturer)
CTD: Cummins Turbo Diesel
CV: Constant Velocity, as in CV Shaft or CV Joint
D
DA: Dual Action (as in powered buffer)
DB: drop bracket (suspension)
DD: Daily Driver
diff: differential
DIN: the standard 2" size stereo head unit (1.5DIN is 3" and 2DIN or Double DIN is 4")
DIS: Dealer Installed Swirls (mod), what happens when the dealer details your ride.
DMM: Digital Muliti-Meter
DOHC: Dual Overhead Cams
DR: Donahoe Racing (aka DRE, shock and coilover manufacturer)
dyno: dynamometer
E
e-locker: electronic locker, a differential that is locked electrically
ECM: Engine Control Module
EFI: Electronic Fuel Injection
F
FFV: Flexible Fuel Vehicle
FI: Forced Induction (super-charged or turbo-charged)
FSM - Field Service Manual
FWD: Front Wheel Drive
H
HD: Heavy Duty (referring to suspension usually)
HID: High Intensity Discharge (lighting)
HP: Horse Power
HU: Head Unit (car stereo)
HVAC: Heating, Ventilation, Air Conditioning
I
IFS: Independent Front Suspension
IM: Intake manifold
IMS: Intake manifold spacer
IPDM: Intelligent power distribution module
IRS: Independent Rear Suspension
K
KC: King Cab
KPH: Kilometers per hour
L
LCA: Lower Control Arm
LD: Light Duty (referring to suspension usually)
LED: light emitting diode
LPK (L/K): Liters per kilometer
LSD: Limited Slip Differential
LTPWS: Low Tire Pressure Warning System
LWB: Long Wheel Base (same as CCLB)
M
MAF: Mass AirFlow sensor
MD: Medium Duty (referring to suspension usually)
MIL: Malfunction indicator light (may refer to any of the warning lights on the dash, commonly used in the FSM)
mod: modification
MPG: Miles Per Gallon
MPH: Miles Per Hour
MT: Mud Terrain (tires) or Manual Transmission
MY: Model Year
N
NA: Naturally Aspirated (non Forced Induction)
NAV: Navigation, usually refering to the factory NAV option.
O
OBA: On Board Air (hard wired and permanently mounted compressed air system)
OBD: On Board Diagnostic (aka OBD-II)
OBO: Or Best Offer (usually related to the sale price of an item)
O/D: over drive
OE: Original Equiment
OEM: Original Equipment Manufacturer
OHC: Over-Head Cam
OME: Old Man Emu (suspension company)
OR: Off-Road package
P
P4x - Pro4x
PC: Pro-Comp (suspension/wheels/tire manufacturer)
posi: posi-traction (limited slip differential)
pumpkin: differential
PRG: PreRunner Greg
PSI: Pounds per Square Inch
R
reso: resonator
RF: Rockford Fosgate (audio equipment) or Radflo (suspension) use context to figure out which one.
RWD: Rear Wheel Drive
S
SAS: Solid Axle Swap (replacing IFS with SFA)
SAW: Sway-A-Way (shock and coilover manufacturer)
SC: Supercharger
SES: Service Engine Soon (same as CEL)
SFA: Solid Front Axle
SL: Suspension Lift
SLR: Spencer Low Racing
SMOD: Strawberry milkshake of death (when the transmission cooler at the bottom of the radiator fails and allows coolant into the transmission)
SOHC: Single Overhead Cam
SPC: Specialty Products Company (generally in reference to their UCAs)
SRA: Solid Rear Axle
SRI: Short Ram Intake
SRS: Supplemental Restraint System (air bags)
SS: Stainless Steel
SSV: Speed Sensitive Volume
T
TB: Throttle Body
TBI: Throttle Body Injection
TBS: Throttle Body Spacer
TC: Turbocharger, Total Chaos (Arms), traction control (look at context)
TNX: thenewx.org
TOTM: Truck of the Month
TOTY: Truck of the Year
TPI: Tuned Port Injection
TPMS: Tire Pressure Monitoring system
TPS: Throttle Position Sensor
TQ: Torque
TS: Titan Swap
TSB: Technical Service Bulletin
TT: Twin Turbocharger; also can mean Travel Trailer, TitanTalk
U
UCA: Upper Control Arm
UDP: Under Drive Pulley
V
VDC: Vehicle Dynamic Control
VIAS: variable intake air system
VTEC: Variable Valve Timing and Lift Electronic Control (Honda proprietary)
VVT: Variable Valve Timing (generic)
W
WOT: Wide Open Throttle
Forum Terminology In General
AFAIK: As Far As I Know
AFK: Away From Keyboard
BNIB: Brand New In Box
BTW: By The Way
Bump: Posting in a topic to show it as active.
DIY: Do it Yourself
FIFY: Fixed it for you
FS: For Sale
FT: For Trade
FTFY: Fixed that for you
FTW: For The Win
FUBAR: F**ked up beyond all recognition or all repair
FWIW: For What It's Worth
FYI: For Your Information
GB: Group Buy
IIRC: If I Recall Correctly
IM: Instant Message (AIM, ICQ, etc.)
IMHO: In My Humble Opinion
JMO: Just My Opinion
LNIB: Like New In Box
LOL: Laugh(ing) Out Loud
Mod: Moderator
NIB: New In Box
NSFW: Not Safe For Work (probably don't want to look at it while at work)
NWS: Not Work Safe (see above)
OBA: On Board Air
OBO: Or Best Offer
OP: Original Poster or Original Post
OT: Off Topic
OTD: Out The Door
PITA: Pain in the ^ss
PM: Private Message
PS: Photo-Shop
QFT: Quoted For Truth
ROFLMAO: Rolling On Floor Laughing My A$$ Off
STFU: Shut The F*ck Up
TLDR: Too Long, Didn't Read
Troll: Someone who posts only to cause trouble; troublemaker
TTT: To The Top (bump)
WTB: Want To Buy
WTT: Want To Trade
YMMV: Your mileage may vary
Thank you very much glamisdude for consolidating and organizing the lists. And thanks to everyone else who has contributed to the list.
If anyone has any additional suggestions, please notify me or glamisdude and we will update the list.
OP, if any of the acronyms that you were wondering about didn't make it onto glamisdude's list please let us know. :)
I deeply apologize for responding to an old a$$ post but....
please add OBO thanks!::smile:: IDK what definition is
Reactions: lmat
From my military days, "FUBAR".
"F**ked up beyond all recognition or all repair".
Delete if anybody is offended.
Can anyone tell me what FOBs are?
"FOB" is an old word that multiple meanings. In general speaking, it is an item that is kept with keys or on a chain. When pertaining to modern automobiles, most of the time "FOB" is used for the keyless remote transmitters with which we lock and unlock our vehicle's doors.
2014 Frontier SV Crew 4x2
Needs: “YTC’d”. YouTube Certified person after watching 2 or 3 videos to become a (SME) subject matter expert.
Good work
1 - 13 of 13 Posts
