I read that some of our trucks didn't have cabin filters and some did. I was trying to access it but I couldn't see anything behind the glovebox. The glove box only tilts forward slightly even with the rubber out of the way.
Thanks. Question: It doesn't say exactly how to remove the glovebox so I'm thinking the glovebox some how just pops out when you remove the rubber pins?The full step by step process is shown in your owner's manual on pages 8-23 and 8-24. If you can't find the copy that came with your truck, the owner's manuals are available for free download at Nissan Publications
Heath
Pinch both sides of the opened glove box and pull downward. The single 'pegs' on both sides must clear the edge and then the glove box will drop down, allowing you to see the cabin filter access door held closed by a small screw. Remove the screw and remove the filters one at a time. You can buy replacement filters at most auto parts stores.Thanks. Question: It doesn't say exactly how to remove the glovebox so I'm thinking the glovebox some how just pops out when you remove the rubber pins?
