I'm am planning to wire a ACC distribution block in my frontier and have a question.
My plan is to run a 12 gauge wire with 30 amp fuse. Fuse tapped into one of the ACC fuse located by the passenger side.
My question is will the thin gauge factory wire of the ACC source support up to 4 ACC input? I will be mainly powering my backup camera, radar detector, iDatalink Maestro and rear view mirror.
Thanks in advance.
Found a diagram.
Basically Pin 87 goes to battery
Pin 86 Ground
Pin 85 ACC source
Pin 30 to distribution block
Is that correct?
in a nutshell, yes.
Easier way to think of it... 87 & 30 are your load side of the relay. one pin (either 87 OR 30) to source and other to device. 85 &86 are a electromagnet coil to activate the relay. One pin to ground, one to the switch with the switch going to 12v... OR you can apply 12v to one side of the relay and the switch is ground.
