2012SV, AC works great until it has been run extensively in high heat then it gets warm. If I shut it down for a while it will run cold again. Any ideas on cause and solution. Thx, saw nothing on this when searching.
Get it recharged. You can buy a kit to diy but DO NOT BUY ANYTHING WITH STOP LEAK.
Stop leak will trash your condenser. Ask me how I know
Mine has done that since day one. Apparently something in/around the compressor freezes up and needs thawed.
I've had it checked and it's full of gas, so that's not the issue.
Actually, Stop Leak will trash everything !!!
You need to find out what's wrong. Could be low refrigerant, but don't blindly add, the existing refrigerant must be weighed to find out if the charge is correct, and any leaks fixed if low, then correct amount re-added after system evacuation. Low refrigerant could be causing freeze up of evaporator blocking/decreasing air FLOW - is that your true symptom?
Otherwise condenser cooling fan(s) could be the issue - does this happen around town or on the highway???When not operating well, is the CENTER of the compressor turning or stationary? Could be a gapping issue where the magnetic clutch is not holding as things heat up, often a spacer can be removed in that instance. Sometimes tapping - be careful and cautious, danger from moving parts - with a hammer handle to see if that engages can help troubleshoot that, as can a test for voltage at the compressor clutch.
Thx for input. Just looking for ideas. Last post sums up pretty well. Traveling so looking for quick input. Wait till I get home and have my local guy chk it out. Again, thx
