1 - 3 of 3 Posts
04 xe, 75000 miles. when my ac comprsesor kicks in i get a vibration/ noise. sounds kind of rumbley. the ac works great. has anyone encountered this?it is not the fan, it only occurs when the actual compressor kicks in.should i worry? thanks ahead of time fo4r replies
sounds like the compresor in dying. an a/c tech can add some oil but it is probly to late. make sure the bolts are tight. then run it till it dyes. good luck
Just lately, my A/C has been making a steady low droning noise. It makes the sound whenever the A/C is on. Whether the compressor is working or coasting makes no difference.
I opened the hood and peered around and the drone eminates from within the engine bay, but I cannot determine the source. I put a mechanic's stethescope on the compressor and it sounds okay. Seems unlikely that the small A/C fan by the radiator could make such a low pitched sound, but I suppose it could.
A/C is running fine. Any ideas?
1 - 3 of 3 Posts
