The ac clutch wont engage on my 98 frontier. I have checked every wire and component that i can see on the schematic and everything seems to be ok with the exception of I am not getting a ground signal from the ecu or pcm as the book calls it. Should the compressor clutch engage if you have the pressure switch jumpered even if the system is not running at the correct pressrues? What determines when the ecu tells the clutch to engage? I can get the clutch to engage if I jumper across the relay like the book tells to do as one of the checks. After that it says to take it to a dealer to have the PCM and related circuits
checked. I'm lost. Not that keen with electrical problems as it is. HELP!!
