Hey all new to the forum, recently bought a used 2013 frontier V6 4L, hoping someone has some insight for me
Started a while back on a snowy wet highway, my truck stuttered and ABS and TC lights came on, lost both systems ( also 4x4 )
Tried resettings the ECU, both manually by removing the battery ( connected leads to drain system for over 20 min ) Also found a procedure to reset by a systematic series of flooring the gas while key is in acc mode
Initially this cleared the issue for a day or two but expectedly the issue came back, Ive tried to repeat but with no luck.
Ran a scan and got codes C1109 ( Abnormal voltage ) and C1102 Left rear Abs sensor
Performed a test on the sensor with multimeter, the sensor checked fine but the voltage to the connector was weak ( double checked both sides.
I was also due for a new Battery, temps were around -28C for 2 weeks and start up was rough so I installed a new one.
Also I thought Id check for recalls and there was and ECU update needed for airbags, had the dealer do a diagnostics while I was there, all they did was confirm what I knew, sensor was fine power to the connector was weak. I opted to not have them dig deeper as its the dealership and their shop rates are crazy! Worst case if I can't find the issue I'll take to my guy
Since it was so cold and I don't have a heated garage this was all put on hold for a few days when low and behold out of no where the whole system comes back online and stays that way for about 2 weeks.
Well its back now, Ive chased the wire all the way through the undercarriage up to the ABS actuator but its impossible to see if there's a short because those wires are in a super channel of a bunch of other wires. Any exposed wires near either end seem fine.
Finally found a diagram for the harness and I'm going to try probe to see if that can reveal anything.
Anyone have this problem and could suggest something I can try, giving myself one more go at this before I tap out and take it to the shop
