? about utilitrac
1 reading
1.9K views 5 replies 6 participants last post by  Krillz
#1 ·
Are the rails on the sides of the beds in two pieces? When i bought my truck it had only the two rails on the floor. I need the side tracks over the floor ones for hauling my quad. I have found the front one on courtesyparts.com, but the side ones i think i found but It shows them to be split in two. Are 93390m and 93396v the right part numbers for the side rails?
935 Side Gate & Fitting :: Body(Back Door & Rear Body) :: Genuine Nissan Parts :: Frontier Parts (D40) 2005-2010 :: Nissan Parts, NISMO and Nissan Accessories - Courtesyparts.com
#3 · (Edited)
Yes, they are two pieces. I'm assuming you bought your truck used. If so, there is the possibility that the ones in the floor were added by the previous owner. If that is the case, your bed more than likely doesn't have the braces/structure to mount the utilitrack safely/properly to the sides of the bed. Just a warning and something to look into.
#4 ·
The rails are made in two pieces so if in a wreck the bed can collapse. Otherwise the rail could be pushed through the bulkhead and enter the cab.
