Can the a/c clutch be replaced? My a/c blows very cold air,but the clutch is slipping and making aloud metal to metal noise. Its not the belt .Ican see the clutch slipping.
It can be replaced, but the clutch coil will be the culprit. The clutch plate and coil should be replaced together. Make sure you have the proper voltage at the coil before replacing. Too high a voltage drop and the coil will not be able to create a strong enough magnetic field to hold in the clutch plate to turn the compressor, hence the slipping. Have the system pressure's checked. There is a possibility you may also have a bad hub bearing or compressor too.Can the a/c clutch be replaced? My a/c blows very cold air,but the clutch is slipping and making aloud metal to metal noise. Its not the belt .Ican see the clutch slipping.
Its a 2000 king cab,with a ka24de. Thanks.On most AC compressors the clutch is a separate item so it should be replacable.
What year? What motor?
