1 - 9 of 9 Posts
Just got this basket case back together today. Bought it with bent valves. Removed the head and replaced all 8 intake valves. Assembled the engine and timed the came accordingly. It seems to only want to run with the distributor fully clockwise and beyond with the 2 mount bolts removed. The distributor shaft only goes in one way. What did I do wrong and is it an easy fix?
Bob
I would double check TDC for starters.
I just checked. At TDC the rotor is pointing towards #1 cyclinder. The distributor cap is another thing. The rotor is north of number one on the cap. There is not enough turning in the distributor to bring it in line.
Maybe its the wrong cap?
The previous owner was backing in his driveway when the chain broke. He had already did a complete tune up prior to chain breaking. So it is the correct cap since it was running.
Also, I have a diagram showing that number one on the distributor cap is at 1 oclock then 2, 4 and 3.
My Haynes manual shows number 1 on the cap being at about 7:30
What is correct?
Thanks
Bob
My #1 is at 12 o'clock, but its a 98 and I don't know if there was difference.
However, you're saying you have to advance it so I'm going to guess that your distributor is off by a tooth or two.
Pull the distributor out and advance it one tooth, reinsert it, and see if you now have the rotor pointing at the #1 connector on the cap. That's what I would do anyway. I know it can be hard to get the timing marks on a distributor just right. :)
Are you using the process in the manual for setting the timing? Its not just a timing light.
Got it figured out! I set TDC, removed oil pump and shaft, set the distributor on #1, installed shaft until it was set with flat side toward engine, installed the oil pump and all is good to go! Runs awesome.
Bob
Actually you cannot do a tooth at a time since the mating of the drive shaft and distributor are offset so they can only align one way. In order to set it right you have to remove the distributor drive shaft, set the rotor on #1 on the cap, slide the drive shaft in and out until the flats line up. Install the oil pump and that's it. You won't find that in the maintenance book. It's not like a normal set up where you lift the distributor and go a tooth at a time.
1 - 9 of 9 Posts
