I've got a 99 Frontier with 353,000 miles on it. I've always self serviced this truck. But I'm running into an issue I can't figure out, and hope someone on here may have had a similar issue. A few months ago I would be driving down the road and feel a slight jerk once in a while. As time has gone by, it has gotten a little more pronounced. It was due for a tune up, so i put in new plugs, wires, dist.cap, rotor, replaced the o2 sensors, and all filters. Since the tuneup the truck has a lot more power. However the jerking only continues to get worse, in fact the other day going home from work, it just died on me. After pulling over, the truck crunk back up on the second attempt, proceeded to drive home and it continued to cut-out. However being manual trans. I left it in gear and the truck would restart itself and got me home. The truck cranks right up and runs great other than the above issues. While at home i let it sit there and idle, after a couple minutes, it would just die or almost die then continue to run fine. (No codes at all)First thing I tried was look for vacuum leaks, found none. I then started thinking maf, as I have noticed my fuel economy was down. I could actually mess with it and mimic the engine dying so I replaced it. I've only drove it a little bit since, it hasn't died as of yet, but I notice it still trys too. I have verified fuel pressure, it's ok even up to the point of it dying. I've read a lot of people have had issues with distributors on these engines and I'm not ruling that out, but it seems to me like if it was losing fire and then getting it back, that I would notice some sort of backfire or smoke, especially when it dies it under load? Btw the inside of my dist. is clean as I see that there are some issues from oil getting inside from other post.
Ideas other than taking it to a $tealership?
